You are going to have to get the manual, read and learn. These guys can generally direct you, but this is a hobby where you should get used to being hands on.
I saw you your other post. Open up the control and touch the two leaf switches together. Been a while since I had a track and field, but id guess there is a test mode, you will see how to get into that mode in the manual.
Also learn to use a continuity tester.
