Looking for a ball saver for a Bobby orr or strikes and spares
DDRlegend21
Wisconsin
I have an incomplete ball saver but I can't find a few of the missing parts. I'm looking for a complete one to use.
you must be referring to the "play-more" post located between the flippers?
if so its a pretty rare/hard to find item, some replacement parts are available so depending upon what you are missing you may want to check with Steve young at PBR or John at flippers.com
i have found missing parts for these and have modified similar parts to make them, work ... good luck with your search
also, steve kupla has the exploded parts diagram with part numbers and list for this thing on his website
Thanks for the info. I'll check flippers since Marco and pbr came up short.
you probably already know this but you have to email PBR with the bally part numbers to receive an accurate answer to them stocking most anything that is not gottlieb
good luck
What parts are you missing? I may have what you need to make yours complete.
I have the cap, rod, and coils but I need the rest.
