ArcadEd
Nevermind, thought I had something.
I may have found a new problem or the problem, just not sure what to make of it.
This board is suppose to run at 5.20v. My power supply out reads 5.20. At the end of the harness (not plugged into PCB) it reads 5.20v. Soon as I plug it into the PCB it reads 4.75v on all test points on the PCB, and the pins on the connector the harness plugs into.
And I really think I am crazy here. Here is a picture of the back and front of the main power connector. I see a trace for the 12v line, and I see a trace where there is no wire. I don't understand how the 5v is getting anywhere. I think I am losing it.
1. When my logic tester lights up both High and Low. The instructions say that mean Square Wave < 200khz. I don't understand that. I thought everything would test, Low, High or nothing.
2. When a PCB doesn't even boot, how accurate is logic testing TTLs? Seems like their proper logic state depends on the CPUs running. Is that correct?
bumping this for some love hopefully.
Hey channelmanic, you feel like fixing 200 of these boards for all of us?![]()
Agree 100%! I've learned a number of things just working with a logic probe and trying to understand the various signals on logic boards and it's probably the cheapest and easiest tool to get started in some board repair. It's helped me fix a few boards so far and ideally I'd like to get a decent test bench going so it makes it a bit easier. Trying to look at thing still hooked up to a full cab can be a pain.Did you ever get the board(s) up and running?
I am very happy to see you learning about the electronics and hope you continue. Do NOT give up, if you get frustrated, just leave it for some time and come back to it.
I still don't fully understand about the timing of things as far as data and address lines but I am learning more each day.
You have been doing well so far, keep it up.
