MundoMan4
Not cost saving upfront, but is long term if you ever have problem with "light" water (like < 1/4" ): Put Dri-Core subflooring down. Runs about $1 a sq foot on sale in 2x2 squares.
Dri-Core at home centers = 2'x2' plywood squares with plastic bumps on the bottom to keep it raised...
I've seen Dri-Core at the home centers, two problems... there is no moisture barrier at the seams, ITS EXPENSIVE.
Instead use its commercial equivalent. You roll down the plastic (4-5 foot wide) and tape/seal the seams. Then put down a floating plywood floor(which you can tile or carpet) or just a laminate/hardwood(like pergo) flooring.
(Lowes carries a version with a fabric barrier for foundation drainage)
Here are a few types...
Delta FL
Platon
Just found some pictures at AVS Forum AVS Forum I'll post some but read the thread for more info...
DAMN image Limit!!!!!!!
Check out this basement remodel here...... http://www.avsforum.com/avs-vb/showthread.php?t=1155374
