litle wells g help
DKJR
Iowa City, Iowa
I just got a great williams multi game built in a original joust cab. pic and everything is great but when your playing games like tetris the screen is to wide left to right. so you cant see what the next piece is on the two player side. a minor disadvantage lol. what adjustment do you need to use. horitizantol width (which is inside that cilinder type thing) or is it a vertical adjustement? I guess Im not great with monitors. I've always wonder this are the adjustments in accourdence with the orientation of the monitor. Or are the adjustments always viewed from a vertical stand point no matter if your game has the monitor in the cab horizantol. any help would be great. hope this isnt to confusing. basically I just need it to be moved in a inch on both side so I dont lose the edge of a few games.
Vertical is always the short dimension.
Horizontal is always the longer dimension.
Doesn't matter how it is sitting in the cabinet.
And always identify your monitor make/model....
What's the model number of the monitor? Horizontal width can be adjusted a little bit with the horizontal width coil, but depending on the model, there may be a horiz pot, or a jumper.
Thanks Ken,
from reading the bob roberts page it seems like its a vertical pot I will be looking for. since its over the longest axis of the screen. However the two post after the link say other wise. I will trying and post the model of my wells gardener after work today.Thanks for everyones help
the bob roberts link tells the reader the oppisite of your statement that the longest axis is the vertical issue and the shortest is a horizontal. The wg model number is 19K7901. So I need the picture to been moved in less than inch from both the left and right side toward the middle. I has some games just off the screen.
