List your current "projects"
Tornadoboy
North Attleboro, Massachusetts
I just got done admiring the disaster that is my work room and thought this might make an interesting topic to see what people have cooking out there.
Here's my current "to-do" list:
- Road Blasters dedicated / used to work but now is just completely dead, I suspect a problem with the ARIII reg/audio board and/or the "big blue" power supply capacitor. I'm withholding significant repair efforts until I'm done with the Turbo and Buck Rogers, and will probably work the whole cab over cosmetically with maybe restored side art.
- Floor model IGT slot machine / Jams on large payouts, I suspect a fried-looking transistor on the main board but I'm not sure, the mechanics have been cleaned and seem in good working order.
- Turbo mini dedicated / My main project, I'm rehabing the whole thing from the cab to the electronics, I'd say I'm about 75% done not withstanding any major electronic problems. Can't find new side art anywhere damn it! :(
- Buck Rogers dedicated / Next in line right after Turbo, and boy this SOB needs a LOT of work! The cab needs a whole new side, kick panel, new CPO, side art, and an overall complete refinishing. The electronics and monitor currently are completely screwed for as of yet undetermined reasons, the included wiring harness was a total hack job.
- Williams board set / I am rounding up a complete set in an attempt to build a one-of-a-kind Alien Arena cab using the prototype ROMS... needless to say I've got a LONG way to go.
- Exidy Victory board set / It came stripped of EPROMs and memory chips but IMHO it's a cool game and I'd like to restore it to good working order, then hopefully give it it's own mini-cab someday.
- Monaco GP mini dedicated / I've got two cabs actually, both need significant cosmetic cab work and were stripped of their PCBs. I've got enough parts to restore one, the other will probably end up as some kind of conversion experiment.
- 60 in 1 PCB / It needs a good home, I haven't decided whether to use my Buck Rogers cab or more likely my extra Monaco GP, or perhaps just build it it's own mini from scratch.
- Spy Hunter mini / slowly rounding up parts and will design my own cab... or at least that's how the fantasy goes... Low on the priority list right now but I'd love to build it some day.
- Arcadia Select System motherboard / currently has Leaderboard Golf installed and is overall untested, I'd like to convert it to the ultra-rare Sidewinder and... yes... give it it's own cab. Would kill to get my hands on the mythical ROMs for NY Warriors and convert it to that, if they even really exist in arcade form.
Here's what I've got:
Playchoice 10:
Need assembly and games. I have the harness in it, and the CP wired up, just have to mount the cage, and wire a new plug for the Isolation Transformer to the power brick
Red Tent:
Have obtained all the correct buttons for it. One side CP done, other side needs cleaned/painted and two buttons replaced. Red part, one side painted on the outside, inside still needs paint.
Neo Geo 6 slot MVS:
Need to wire up the harness, and get a power supply for it. Just going to use a small computer supply for the time being. Also, need to test the monitor with a RGB input.
That's all my projects... and all my cabs :p
I'm working on a Super Punchout. This is part 1 of 9. :) I'm going to work on adding the CPO tomorrow. I've got it primed, painted and sanded already. I just need to add the CPO and remove the adhesive. Since this is my first time, I'm a little nervous. Wish me Luck.
Awesome game all around, and it has great resale value so it ought to be worth the effort regardless!
Assault:
Rebuild monitor chassis w/ new caps and flyback.
Order new T-molding for cabinet
Repaint sides
Time Soldiers:
Fix sound issues (speaker? voltage?)
Bondo/paint bottom portion of cabinet
ok,here goes 1st. trying to finish the game room/ bar. got the game room just about done and started to move in games. 2nd. trying to get my "new" em rifle games from the midwest to my home, mass. 3rd got my target zero apart for 3rd time. 4th got my sea raider working good ,not perfect but good. 5th sea wolf needs pcb and could use new monitor. 6th tryin very hard not to buy every pos that shows up on cl or ebay. ie no.5
1. Super Breakout cab that keeps blowing monitor fuses but plays blind
2. Bally Sente that needs to be converted back into a dedicated (I JAMMA'd it while I was waiting for a power supply, but it's ready to go back to a Mini Golf)
3. Neo Geo MVS 1-slot board that I should get in the mail one of these days. Gotta find a cab and monitor for it, but I've got some promising leads
4. Double (networked) Kaillera MAME cab
  • Build Arcade room for finished machines
  • Finish Lunar Lander scratch build cab
  • Finish vectorizing Lunar Lander Sideart
  • Complete almost finished Starwars Cockpit
  • Get Taito Asteroids Cocktail working
  • Get Battlezone cab working and tidied up
  • Sideart Project for Asteroids Upright
  • Fix spare Asteroids, Lunar Lander and Star wars game boards
  • Get Hot Shot Pinball machine working
  • Build a three sided 23" Mame Cocktail machine
  • Build a Vector / Zektor machine, possibly in the shape of a tempest machine
Any progress is good progress
so, back to the Arcade room project :)
1) Work on Moon Patrol - Cap the monitor, clean up joysticks (tomorrow afternoon)
2) Take apart/clean up Championship Sprint steering assemblies
3) Track down/fix humming issue with the multi JAMMA
Sitting here in the garage, so let's see...
Missile Command:
Current project, 90% complete. Stripped the bad CPO, gotta clean and respray the control panel and then apply the new one. Board is queued up at bit_slicer's. Rest of the cabinet restoration is complete, monitor should be good to go.
IREM Madonna candy cabs, x2:
These will be emu cabs, still gotta strip them down completely, repair the bodies, spray, cut a new control panel, and finish setting up the PCs.
I, Robot:
Still a Choplifter. Have a boardset, but it needs repair work. Cabinet wont need much work, and the hall effect stick is on the shelf.
Omega Race:
Chewed up rear of cab needs work, plus side art. Boards may be okay, have a monitor waiting for transplant.
Sea Devil:
This is gonna need a full teardown and restoration. Should be an interesting project icn the next year or two.
Interstellar:
Stick went to museum, boards to a collector. Cab is in decent shape, Daphne PC is almost all set to go.
Mappy:
Bought this back from a friend... Needs minor cosmetic work, and plays blind. Honestly, haven't really looked into it yet
I've got plenty to keep me busy for a while, so unless an amazing deal or dream game falls in my direction, not gonna be picking up anything new until I've got at least a couple of these finished.
Galaga:
Mew monitor, PCB, 220->110v converter, cosmetics...
Pac Man:
Ms. Pac Man:
Neo Geo 2 slot MVS:
New power brick/transformer.
Gauntlet:
Monitor, Sideart, T-Mold...
Colony 7:
PCB :/
MK2:
Cap kit/New monitor, changing the game from T3 to MK2
Punch Out:
PCB, cosmetics..
GnG:
Applyng CPO..
Operation Wolf:
Monitor, fix optics in gun (!)
Missile Command:
Sideart, PSU, PCB
Sea Devil:
Not many of these EM arcade games around :)
That will be a monumental restore, I will watch with great interest when you start :)
Man, I went from one or two little projects to 9 or 10 quickly over the past month...
1. Centipede needs to be sanded down, filled, painted, and sideart applied.
2. Punch-Out! needs a couple cap-kits.
3. Gorf cabaret needs a cap-kit.
4. Space Encounters#1 needs PCB help.
5. Space Encounters#2 needs PCB help and a monitor rebuild.
6. Super Hang-On needs a cap-kit.
7. Gorgar blows a fuse every so often so I need to look at that.
8. Wizard of Wor cabaret needs a back door.
9. Battlezone#2 needs to be put back together with a non-periscope kit.
10. Long time project Mr. Do needs cabinet reworked(it's in a wrong style Universal cabinet so the control panel doesn't fit correctly).
11. Lock 'n Chase has a minor sound issue that needs to be looked at.
Ugh... that's too much work this time of year... guess I'll just go back to drinking my :coffee: on the deck while listening to the birds. :)
nintendo cocktail
clean up and prep for pending sale tomorrow
dkjr
full restore, fix marquee light
space invaders mini
get coin box open, fix marquee light, make back door
crystal castles
go to delaware to get it, make it work, make it beautiful
gauntlet
get and apply vinyl for front panel, fix it so the wizard can move down, get and install upper coin doors and wiring.
get rid of mother-in-law so this can come home
Sea Wolf: Fix power supply
Sprint 2: Replace edge connector
Asteroids Deluxe: Fix monitor HV cage
Gangbusters EM gun game: Fix issues with scoring
Environmental Cruis'n' USA: Minor monitor work and fix motion problem
satan's hollow - sand and paint, fill lock bar holes, and cap the monitor
tron - go over the chassis for cold solder joints, as i'm getting random dimming and shakes.
eventually get replacement blacklight plastics, as the colors are faded.
mario bros - needs cpo, buttons with correct colors, front panel repainted.
pac man - full g07 rebuilt kit with hot, transistors, flyback.
space invaders - outside cabinet cleaning and waiting on the red overlay for the monitor.
captain kidd pinball - need to wax the playfield, and install my plastics when they
come in the mail.
1. Since I finally stopped bearing children, find a house with enough room to get some cabs up and running :)
2. In the meantime finish my supergun-not sure how super it will be lol
3. Stop googling everything arcade and get to work!
Galaga - Body work, painting, new art package, new power cord.
Revolution X - monitor rebuild.
Tron - body work, paint new art package, new monitor.
That's all for now.
Added to my list:
- Test formerly broken 13" monitor I just attemped a tube swap on (thx for the tube bstnguy!)
- Test and inventory everything JAMMA I have
- Figure out how to program EPROMs so I can stop talking and start DOING!
