Linking San Francisco Rushes
modessitt
Austin, Texas
I need to do this to two sitdowns. I seem to recall seeing a couple Rush The Rock's that had what looked like a router in back with connector (ethernet?) from each machine plugged into it. Is this how you do it? Is it generic equipment?
I'm used to stuff like Need For Speed where you just run a cable from the slave to the master and they're linked...
It's just Ethernet... so if you're only doing two machines, you can simply use an Ethernet crossover cable. If you need more than two connected, you'll need a hub/switch.
DogP
