Light Weight Coin Micro Switches ?
mk3u2012
Vergennes, Vermont
I'm assuming someone has run into this problem before. I have a customer who operates all his games on cheap brass tokens. They don't have the weight of a common quarter and therefor often get held up in between the mech and coin switch. There is no alignment issues. The tokens are clean. They just simply are not heavy enough to actuate the wire of the switch. Quarters work every time.
Is there a light weight alternative designed for tokens?
Blake
