Stepwise is the way to go…
In | In-State | Out | Out-State | Signal | Connectio |
2 | Low | 18 | Low | RDC* | |
17 | High | 3 | High | CS3* | |
4 | Low | 16 | Low | RD* | |
15 | High | 5 | High | CS2* | |
6 | High | 14 | High | UWR* | |
13 | High | 7 | High | CS1* | |
8 | High | 12 | High | LWR* | |
11 | Pulsing | 9 | Pulsing | CS0* | a.) G* (inverted) on IC128 (Data bus buffer to graphics board? b.) Logical signal in CE* of RAM (IC130 and 3 others) c.) Logical Signal in OE* of ROM0/1/2 |
Nonchalantly does a teardown and "quick change" of the gears that took me a month from start --> finish lol. Nice work!Took apart the steering assembly, wiped it down and upgraded the gears. Was happy to button it up with no missing parts or extra parts.
Nice breezy day to pullout the ozone machine and work on the rodent smell. The cutout for the pedal assembly makes a nice duct for the ozone machine to fill the empty cabinet and vent out the top.
I would double check the work for IC 115/130. The old parts allowed the game to boot so this is something that I'd try and sort before proceeding.Well one step in the right direction. I removed the sockets, put new sockets in, checked all the data/address lines, fixed 2 traces that I must have broken removing socketing the first RAM. I socketed IC 114, 115, 129. and 130. This is with the sockets empty.
If I put anything in IC 114/129, I get the exact same errors. If I put anything in IC 115/130, the game doesn't boot.
If DB=Data Bus, I'll recheck the data lines again. I checked for continuity on everything, but I didn't check for shorts yet.
I had to swap a chip on mine and absolutely discovered that desoldering a multilayer board is trickier than a single layer! I had one pin of the old chip that took me about an hour to get out! Installing the socket was somewhat easier but I was very worried I had mangled something by the time I was done.Thanks @ccie38296! Thinking about how it works (or should work) is a lot less frustrsting than randomly swapping chips. Not to mention my soldering skills are a high risk on this board as I have already demonstrated.I did just get a hot air station and ordered a PCB preheater, so maybe the right tools will up my game.
Thanks @GameyMcGame! It took me over a month start to finish if you count how many days went by with it sitting in my garage waiting for me to get to it.![]()
