Light gun question
ngtmareracer
Donor 3 years: 2015, 2021, 2025
Worcester, Massachusetts
So, I have a multi cab with a 6-way jamma switcher, has a multi-Williams board, relief pitcher, multi vector and area 51 site 4. Trying to add lethal enforcer to the cab. the light guns work good for Area 51 but I cannot get them to work for Lethal Enforcer. does it take a special light gun for Lethal Enforcer and if so, where can i buy them. Thanks. Mike
Its a standard four wire light gun. If you are having issues, could be pcb has issue on gun out or trigger. i use a happ unit on LE same as for every other light gun game I repair.
How are you switching the inputs for the guns?
I'm assuming before you had LE in there, you had the guns wired directly to Area 51. When playing LE did you move the guns to the LE gun connectors?
Also, I recall on my LE that I had to put the connectors on backwards for some reason. Perhaps that is the problem?
EDIT;
Are you getting a flash but no tracking in LE? If I recall I was getting a flash but no tracking and flipping the connectors around solved the problem.
I repair very specific platforms from Sega, Konami and Midway. However, I have never had to test guns on any Midway or Atari product. My main repair / testing station is a whole system I have developed at Sega. I just make new harnessing to fit that system and tag each new harness as to what game it goes to. You should refer to game manual for specific connections.
