Liberty bell 100s dont roll over?
Trioxin
West Virginia
I have a late 70s Liberty Bell Pin. I have a problem with the 100s.
once it hits 900 and you get another 100 it rolls over to 000 again without
adding the 1000. so unless your scoring points over 1000 you dont really get anywhere..
what could be causing this? its one of the last mechanical pins of the day. any help?
Does it do this on both players or just one? If both check the 100's relay if just one check the switches on the 100's score reel.
Glennon
both. is the relay under the playfeild or in the score box?
Thanks for the help.
I'm lost when it comes to pinball machines.
somewhere between the 100 point solenoid and the point drum that flicks over the 1000 the wire had been disconnected. so i made a new fresh jumper wire, it worked out great.
