LG/Phillips tube Wei-Ya Chassis problem
RalphT3
Cahokia Heights, Illinois
Hey Everybody!
This is from a Percussion Kids and as you can see that the HV went into the winding on the tube. How screwed am I with this? What would cause something like this? So I guess I need to change the fly-back (how do I know which one I need) and the windings on the tube (where do I get that also), haven't checked on the board yet to see what damage has occurred. If the parts are to hard to acquire I will just order this:
http://www.happcontrols.com/monitors/49271500.htm
What sucks is I had the back opened twice and never touched it and by having the suction cup turned 45 degrees to the right it probably never would've happened.
You're going to need another yoke as well. It would probably be cheaper to find yourself a TV and swap out the chassis with a Wei Ya one. The TV will have it's own yoke so you should be good to go.
Alva Amusement distributes Wei-ya in the USA. Just contact them and order a yoke and a flyback for your particular chassis.
