LF: Sencore CR161 Manual
eh97ac
ON, Canada
Just picked up a CR161 and got an adapter made by Oryk Zinyo.
Can someone send me the PDF of the manual or lead me to a URL
If the door has the label in it, that's really all you'll need.
(I don't have a manual for mine either)
I've never had to really use the Rejuve selections, remove shorts usually does the job.
Number one thing is when setting the gun balance is to let the tube warm up until the meter stops drifting.
BIAS generally gets left on Norm.
Automatic Tracking - never have figured that part out.
If you need any specific question answered I can try to, I just gotta remember to check back as I'm not on a whole lot right now.
Great little units.... not enough love around here for the Sencores. :)
OK So I have the door instructions and sorta did them all (I think I did them correctly). I tried it on my K7300 with green missing.
Success, green comes back and looks awesome. I leave the monitor on overnight and in the morning....no green.
Did I screw it up or is the green gun done for?
Set the gun balance again (think of it as a calibration)....What does the emissions test show for the green gun?
Make sure to check the neckboard and video input headers pins out closely for bad solder joints and such. You don't want to chase a missing color problem just to find out it was something else.
Green is bad (needle is on the left sie of bad) but red and blue do not even register. Is that supposed to happen or should it go into the green zone?
So after 1. re-setting the balance with the selector set on green, and then 2. testing the emissions for that gun ...the green gun shows bad?
Do the same steps for the red and blue (re-balance and test emissions) they should show "something".
You may have to hit each gun 2-3 times to burn off all of the crap. All you need are the instructions on the door. You will need to reset the meter for each gun after each 3 gun rejuv.
