LF: Ground Clip
Level99
Permanently Banned - Anon seller failed to verify
Donor 2016-2017
California
I've been making wiring harnesses for a long time and I know lot when it comes to sourcing materials for them. However, this one part has me stumped! It's a ground clip. I've attached four pics. Can anyone tell me make/model or where I can find this part for sale somewhere?
I'm not sure about those exact ones, but there are several things that would likely be usable as replacements.
Fastex makes a part ( http://www.itw-fastex.com/catalog/index.php/dw/op/a/3/c/5/p/55?m=no ) that has the ground clip with either tabs for quick disconnect, or IDC. You can buy them here: https://www.biscoind.com/Fastex/8182-84-00-0555CT .
You could probably also use the ground clips used on electrical boxes, like the Raco 975: https://www.grainger.com/product/RACO-Steel-Grounding-Clip-2DCN3 . They're generally dyed green though maybe they make them undyed, or you could just live with them being green.
DogP
I use those ITW/Fastex on almost every Atari wire harness I make, so I'm stocked up on those. I try to keep my repro harnesses as close to original spec as I can, which is why I'm trying to find these odd looking clips. I'm wondering if anyone out there has seen these and know at the very least who originally made them if nothing else.
Anyone else have any ideas on this one? I found this on a Spy Hunter cockpit MCR harness I'm documenting/reproducing. I'd like to stick with the original component if I can. I really hate to ask for help on something I consider myself an expert on, but this part truly has me stumped! I've never seen it before on anything else I've worked with.
