LF Gravitar Black Widow wiring harness
I'm sure this has been asked before, and it's probably a stupid quesiton, but wouldn't a space duel wiring harness work?
pinouts and voltages seem to be good. (again if it's a stupid statement, sorry) lol
do you have a Space Duel harness? they are close, the inputs are different and will require modding. In a pinch I could use it...
mh
With the Space Duel harness in the Grav cab, you'd still be limited to 2 speakers but you could play Grav, Space Duel, and Black Widow all in the same cab if you have the panels. Using the adapter, the SD panel will play Grav so all you have to do is swap the board and add/remove the adapter. Alternatively, you can reorder the pins on the plugs of the Grav and BW cp's to plug into the SD harness directly.
I put together a nice parts list and wiring table that you can use to make a nice adapter that connects the Grav cp to the SD harness...
http://www.biltronix.com/pdf_files/Biltronix_Space_Duel_Control_Panel_Wiring_Adapter_to_Play_Gravitar.pdf
Bill B.
