One other thing. Is it better to jump and then move in the air, or start to move in the direction you want and then jump? Is there a difference?
It doesn't really matter, he jumps the same distance either way(as far as I can tell)
After round 12 it's usually safer and more accurate to jump and then move.
jow.....how far do you usually get in the game...I'm guessing that you don't very often get past the 3rd lion stage(50k lions)??......when I first started to play I had a LOT of trouble with the 2nd and 3rd lion stages....they are very hard to get through ......but in saying that, they are a walk in the park compared to the 4 net stages.
Some things you might not know about the game.
1.....after round 10, every second coconut stage has invisible platforms.
2.....you don't have to jump right over the animals to register a score(you can jump over the top of them, then return to the same side you jumped from..it will count as a jump)
3.....your points for landing on the top platform on the coco rounds doubles each time you land on the top platform(get to the top, then jump down to a lower platform, then jump up to the top one again, and so on) ...eventually after a few jumps you will be getting 300k for each time you jump onto the top platform.....not worth the effort...you will get killed 99.99999999% of the time.
4.....after you get killed, the animals exit and run just a little faster...they also nibble away at your walls with more vigour.
5.....after round 19 .....the game starts counting the rounds starting at 10...there is no round 20, 21 etc.
6......Jason Cram set a new Twin Galaxies world record for ZK a few weeks ago....38.2 million...beating his brothers existing 35.7 million.
john
