Lets play "Name-the-monitor-thats-in-my-Golden-Tee"
TheDrewster
Donor 2012
Reno, Nevada
It is a 25" WG monitor in a Konami TMNT cab. I cant figure out what model it is. the tag is gone and I cant find a close match with Bob or WG's website.
It depends on the screen-resolution dip switch setting on the GT board.
If it is set to standard resolution, then it is a K5501.
If it is set to medium resolution, then it is a K5515....
There is misinformation in that link.
The monitor chassis shown here is a K4915/K5500 Medium Resolution chassis.
Actually, the med-res 25" chassis is called a K5515.
It is easily identified by the small circuit board attached to the top of the left side frame.
The standard resolution monitors do not have this additional board.
This is not true. I have a standard-res K5501 (labeled) in my Lethal Enforcers and it has this small board mounted. Some have said the standard-res will have it but it won't be hooked up, but mine is hooked up...
Just order the 5500 cap kit and you'll be fine. If bob doesn't specify, the 4900 will probably work. it's been a while since I've done one....
