Lethal weapon 3 restoration
drwicket
Nebraska
Hello,
I am in desperate need of a high res scan of the playfield plastic in the upper left of this machine. It is the piece with the blue light attached to it. It is of a guy wearing a helmet holding a machine gun. My piece is cracked in half and badly damaged. I need a high res scan so I can print it off and piece something together myself. Would greatly appreciate this or if anyone knows where I can get a replacement piece that would also work.
Also need the blue dome for the top of the machine if anyone knows where I can get one.
THANKS!!!!!!!!!
Plastic scan
Hello,
I recently purchased a Lethal Weapon 3 machine and also need the same scan as you. Most of the rest of the plastics on my machine are in good shape. If you need scans of other pieces, let me know.
Martman
plastic scan
All the other plastics on mine are good as well. Sadly I have had no luck getting a scan or finding a replacement. If I get anything or find where replacements can be found I'll let you know.
Plastic scan
Same here, if I locate a part or the scan, I'll email you the info. Hopefully there is someone out there with plastic or scan that we need.
Regards
plastic scan update
I am going to scan the piece I have and touch it up using photo shop. I will send you a copy after I am finnished with it. Hopefully it turns out ok.
scan completed
I got the scan all cleaned up if you still need it just let me know I can send you the original and the fixed version.
