lethal weapon 3 display garbage question
kuglerarcade
medina, Ohio
does any one know why i would get this is on display.it should say free play on the bottom of the dispaly.also in test mode display checks out fine.any help would be appreciated thanks
Completely guessing that the display rom is corrupted.
On a similar note, Punkshere2Stay has an issue with his LW3 display also..
Also works completely fine in test mode, but the DMD animations are messed up for certain things. =\
Hey BOB are there any related roms you could try reseating?
Also did you get my vmail? Shoot me your email addy.
If you have another DE try swapping ribbon cables and see if that fixes it.
Any luck with this problem? I have a similar issue and haven't been able to solve the problem yet.
i tryed reseting the rom chips with no help.i did rule out the ribbon because when i set the game up for quaters evey thing is easy very read able.so i would say corrupted rom.i may replace them because i do have 1 buyer interested and a friend interested if my friend buys it and fixes it i be glad to post results.Thanks for everyone help.
Lethal Weapon Display
Hello,
On the display board there is a reset by shorting two copper foils, if that doesnt work ,measure the 68 volts off the power supply
lw3
i has having an issue with mine. and tested it in other de machines getting the same effect.. i replaced with new rome and same thing. my pinball tech then told me the driver board needs to be replace.. no biggie. i decided to sell it as is. good luck.. id guess its the dmd driver board. the dmd in that video looks like its going bad.
