Macubus
I have a chance to pick up a lethal enforcers for 200 bucks. Right gun doesn't work and the sound doesn't work evidently.
Is it worth 200?
Is it worth 200?
I used 99% Isopropyl and probably some Goof Off with Q-Tips. I wouldn't worry too much about it, but if your citrus strip is the real thick kind I'd be worried it would make everything unpleasantly sticky.Do you think citrus strip will strip off that lacquer? That's what I'm going to try first since it seems to be about the most gentle thing I can find.
Does the machine have the original revolver style guns or are they Happ 45 guns? Parts for the Happ guns would be much easier to find.Thanks for your information, this community makes things so much easier!
Next question out there is one of the guns doesn't work. I suspect it's just a sensor, so if that's the case, are there any sources for those?
It depends what "doesn't work" means.Thanks for your information, this community makes things so much easier!
