lethal enforcers shooting questions
punkshere2stay
Donor 2012
fort worth, Texas
my guns work when i point them right at the screen but if i try and stand in front of the game and shoot like it would at the arcade it wont work.??? cleaned the mirror and monitor and the guns? what am i doing wrong? one other thing there is no front glass...
Well, you DID put the mirror back in properly, right? Does it do better in a dark room? Too much ambient light will interfere with how well it works. Also, check the +5 to the gun. If it is a little low, it will affect how close you have to be.
Put it into gun test and see how far you can get with it still working...
well this is what my monitor looks like right now.....wgm2774 what do you think it needs to fix that problem?
it doesn't like to shoot at all in the miss colored area.. i never took the mirror or monitor out of the cab. but they look as if they are where they are suposed to be.... .... dark room didnt' seem to change anything.. im really tall and i was squating down to get mor elevel with the game and that seemed to make it work right except for the messed up color area.
Well, first off, that's either a crappy camera pic or a crappy monitor image. I see way too much blue, too much brightness, and an area that needs to be degaussed.
If this monitor hasn't been rebuilt yet, do that and get the tube rejuved and degaussed. That'll most likely take care of your problem...
where would i get it rejuved and degaussed at? just put a wanted add for someone local to do it for me?? and no it hasn't been recapped
Well, there are a lot of KLOVers up in the DFW area. I figure one of them should have a degausser and/or rejuver.
If all else fails, you can load it up and drive it down here. I have one of my own that works just fine, and also have the rejuv/degauss stuff....
Well thars yur problum.... lol
Yeah, get that monitor working correctly and you should be good to go since you say the gun registers shots at close range. That rules out a gun problem. Pretty obvious its a monitor prob.
i got to looking at the monitor and it looks really blue because in those shots i took it was at the end of a stage and it does blue out the screen like that
ok so i finally got aroudn to checking the 5vdc on my guns. and they where at 4.80 .... so adjusted the 5v on my powersupply to bring it up.... i had to turn it all the way up to get 5.02 volts at the plug in for my gun.... does this mean my PS is going to crap out?... after i adjusted it the guns worked fine and would shoot like they where suposed to other than in the part of the monitor that needs to be degaussed
lol so i need to be looking for a power supply....... now do you replace the big metal covered ones with the little happ switcher? so am i going to be looking for one of these big things?
