Lethal enforcers problem
Hmm that's odd. My LE showed a similar screen before it crapped out completely. Turned out as mod suggested that my power supply went bad. Dropped a new one in, adjusted the +5 voltage, the game played perfectly.
You never mentioned if the game "plays blind" or not. Meaning when you power it up does the sound play when you start a game or coin up. That would help in the diagnosis. But if that connector is indeed the problem I guess you have it figured out.
thanks, no it dont play blind. when i first power it up it makes a loud sound for a second and then nothing.Im gona mess with those wires and se if thats it.
Sounds like you still need to check the power supply readings if it doesn't play blind. Even if the monitor had a problem (bad connection, etc.) the game would play blind if the board set was fine and the power supply was fine.
Also, as others said, if you have another JAMMA cabinet (that is known working) you can plug your LE board set in and see if it powers up.
Working on these games is initially about isolating where the problem is likely located.
yup. i just pluged it in to my street f cab and it worked, the screen was upside down but it worked.
