Did you move the game or do anything to it other than just turn it on one day and have the green screen?
Any game sounds if you coin it up and start a game?
Follow the power cord in until you find the power supply, then look for and check all the fuses (with a meter).
Then go to the connector on the board and verify you have +5 there:
Page 4 of this manual will show you where to check....
ok. i found the problem the wires in the pic come from the small box on the floor in the cab.its the purple and white wires in th pic, they start from that little box in the right pic, they go behind my monitor ,,if i squeeze the connectors where they meet."the white connector in the midle pic" i get a picture for a second or 2, and when i let it go it goes green again. i think its the connector. im going to try to make a better connection and se if that fixes it.Can i get zaped at all messing with those wires or that connection?
