is it possible we can make a list of all possible shooter pcbs that are a direct swap along with others that need some modding maybe something like this.
any other titles? great info so far guys, I was really curious about this.
I've posted similar info in probably half a dozen threads over the page year or so. I really should keep a link to it handy, as often as it comes up.
Regarding your list: I think that Maximum Force will likely require the yoke wire swap (if you have a mirrored cabinet), as well as "Area 51/Maximum Force Duo". Also, as I explained, a gun adapter is not needed for Happ guns; it only
appears to need one (due to the 8-pin connector). Finally, as yaggy pointed out, Zero Point required gun and sound wiring adapters.
Re other titles:
Tho I don't have it, I'm pretty sure "Egg Venture" will work in a LE cab (assuming
The ArcadeSD board doesn't currently support any gun games, but it has a Happ gun connector. It is planned to eventually support some of the old Nintendo shooting games (Duck Hunt, etc.)
I've never hard of Lethal Enforcers 3, but I'd say there's no chance in hell it'll work in a LE cabinet.
Darren, impressed that you know to flip the yoke wires! I think a mirror cab is best for gun games
Yeah, I like mirrored because it appears that the monitor face is at the back of the cabinet. In direct-view monitor gun games, shooting at the screen point-blank range seems too easy. The yoke wire switch is pretty easy. Just unplug the yoke connector, identify the vertical wires (yellow & brown on mine), use a pin removal tool to release the pins, and re-install them into the connector housing reversed.
