Triton2k3
Hi,
First time posting here. I searched for a little while on this topic and am somewhat confused. I bought a Lethal Enforcers cabinet recently for $15. Originally when starting it up it smoked a little. I blew it out a little with my compressor and the monitor started up the next time I started. Everything comes up ok, but I am getting a EEPROM Q2 error after holding the test button. I read somewhere that holding the test button might clear the error but it has not. I also read that the EEPROM is a chip that I can remove and change or clean if needed. Knowing that I searched to find the chip and from what I am seeing it is a soldered on chip, is that correct? Is there anyone that can direct me to the correct chip that needs to be replaced? Is there a better way to go about this?
Does anyone know of a place that repairs these boards? The machine is spotless. I had originally bought it for the cabinet, but I'd like to keep it all original if I can. I am assuming the sound works as it makes a loud noise at startup.
I have also been looking for resources to explain these machines better. Does anyone have a good place to start?
Thank you in advance.
