Lethal Enforcers 2: No Sound and Gun 2 not working
Lite
Michigan
I have a lethal enforcers 2 system that i finally got up and running, and it has no sound (lights at the top by the speakers dont work either if that helps any) and also has an issue with the second player gun (blue one).
I dont have the keys to open the doors in the front, so might it just be that theres a switch in there for the speakers that is turned off?
And, as for the gun, it works if pointed really close at the bottom of the screen, but nowhere else, does it just need to be aligned, or what? how do i align the guns if so?
You can't align the guns. Clean the screen and the mirror and the bezel (inside, too) really good, turn up the brightness a bit, and turn off any unnecessary lights in the room. might need to clean the lens on the gun, too.
Put it into the gun grid and see where you can shoot and where you can't.
And you could always check to see what your +5 is at the gun connector....
As for the sound, I believe there is a volume control inside the coin door, but it's been a while.
There is a manual on arcarc.xmission.com
i figured out the sound, had to press the button to go into the setup menu and change the volume. (i got bored and jimmied the doors open with a screwdriver)
as for the gun, i cleaned the gun and the screen, and it is working a little better, but it still wont shoot the left and top quarters of the screen, any ideas?
Did you turn up your screen brightness some? It works off the amount of light it gets from the monitor. Not enough, or too much interference from dirty glass/mirror/tube or too much ambient light from around the room, and it'll have problems...
yes i tuned the brightness up, even tried it without the lights on, and its still not working, gun 1 works perfectly
you may need to take the gun apart and check the opto. they have a tendency to get cold solder or dust on the opto...
