Lethal Enforcers 2 Gun Issue
RILaw
Donor 2013, 2015
Rhode Island
So, I have an LEII cab that I swap between LE1 and LE2 pcbs. I have been running LE1 in it for a few years and swapped back to LE2 today. After swapping I found that the player one gun does not register, the screen just flashes when I pull the trigger (No gunshot sound), player two works fine. I swapped guns and the problem stays on player one so its not the gun. So it appears to be a board issue... Any ideas?
I had the same problem with the Lethal Enforcers at work. it wound up being a chip issue. I don't remember the part though. do the 2 games run similar hardware?
EDIT: surveying the schematics it doesn't look like HIT1P goes through any standard TTL. the numbers make it look like it's something custom?
