Cartouche
learning to test horizontal output transistor - odd readings?
I'm trying to test, for practice, these two horizontal output transistors. It's the part# 2SD1938, I believe referred to as a 220 package?
One is new from Bob Roberts, the other I removed from a wg19k7905 I'm attempting to rebuild.
I was under the impression that to test this with a DMM, one places:
1. red to base, blk to emitter = junction drop ~ .7
2. red to base, blk to collector = junction drop ~ .7
3. blk to base, red to emitter = open
4. blk to base, red to collector = open
5. blk to collector, red to emitter = open
6. blk to emitter, red to collector = open
I test the old one, and results are:
1. .07 (way too low, right?)
2. .49 (ok)
3. .07 (should be open, right?)
4. open
5. .52 (ditto)
6. open
I figure, good idea to replace this - 1,3, and 5 say bad transistor.
More importantly, the brand new Bob Roberts one shows:
1. .53 (good)
2. .48 (good)
3. 1.67 (huh?)
4. open (good)
5. 1.78 (huh again?)
6. open (good)
On both transistors, I get readings at 3 and 5 - so am I misunderstanding something about testing these puppies? Or are both transistors be bad?
2. .49 (ok)
4. open
5. .52 (ditto)
6. open
1. .53 (good)
2. .48 (good)
3. 1.67 (huh?)
4. open (good)
6. open (good)
