I've got a happ leaf switch flight stick. one of the switches is in dire need of replacement. The tab that you run the ground to is snapped off. Is there a way to remedy this? Better yet, is there a way to convert the stick to microswitches?
I fixed a broken leaf on a Wico stick by melting the plastic bracket back a bit to expose some of the metal, sanding the ends and soldering it together.
Not sure what the Happs are like, but they probably don't use as high quality leafs and switching to Microswitches? Wouldn't you prefer not hearing that annoying as hell clicking sound?
This is an older one, I think it's a happ because it looks almost identical to their microswitch model. If I could convert it over I would. Right now I'm looking at those long "leaf" microswitches and somehow rigging up a bracket.
