That's one of those ones that nobody's been able to prove that it's a Wico (though it's been suspected), but they're functionally interchangeable, and IMO they're actually made better than standard Wicos, as the leaf switches are held on by bolts, and not the plastic clips found on standard Wicos. Otherwise the design is very similar to Wicos, and they use the same Wico grommets, shafts, leaf switches, and they have the same bolt pattern.
The bolted on switches make for a more precise stick IMO, as the plastic Wico clips allow the switch to move around a little in the holder, whereas the bracket-mounted switches have no slop.
It might help potential buyers if you can identify if it's a 4 or 8-way. Are the holes in the top and bottom halves of the base round (8-way), or diamond shaped (4-way)?
