lcd kits?
mdrago
Crestwood, Missouri
i know a lot of you guys are totally against putting lcd's in games but for 48-in-1's it is a little more appealing to people outside collectors. wheres the best place to get cheap ones in a 19"? im seeing them for like $400-500. if this is the going rate then its not even really worth the time to build one and sell for like $1000 now is it?
just trying to see how most of you guys are doing this. im sure this has been covered a thousand times but i didn't see it anywhere.
Can't all the multi-boards put out VGA? I would just run a PC LCD (or CRT).
Yea a regular PC LCD or CRT monitor will work just fine.(which you can get for around $130 bucks or less on Newegg.com)
Now it won't look as good as an arcade monitor. But it will work nonetheless. Just make sure you flip the dip switch to VGA on the 48 in 1.
