gwarble
played around with a mirror, flexible but stiff plastic pulled from another (non-machine) blacklight fixture, "hinged" it to the blacklight fixture with tape, and i could swing it through an arc and see a visible improvement in the lower playfield when focused (pointed really... i'm just relying on the curve the plastic already has for the focus)
then i tried anchoring it while watching in a mirror in the other hand to find that sweet spot... (not as easy without a friend)
i don't know if the picture shows, but there's a noticable improvement... with a little more care in positioning this might be a good easy solution... at least until rich's led's are available (i have to admit i'm a little skeptical about hiding them from view... i already have to bend over too far to play this, if they are hanging down in front of the actual playfield they'll have to be really low profile)
the plastic is visible by about 1/4" from the front of the cabinet (and its probably about an inch and a half wide, so it'd be easy to shorten it a bit)
just an idea
i also got the monitor lined up a lot better... adjusted vertical size to widen the playfield... the sides look good now but the center drop targets are too wide for the playfield "cone" above them (especially on the left side, as you can see) hopefully i can tweak that in perfectly
(first pic is before the mirror, second is with it, can't really see much difference
just an idea
