spanks_4
At first the targets were dropping fast like they're supposed to, but the assembly was having issues pushing the targets back up. So I pulled the assembly apart last night, cleaned everything, replaced the sleeve, but still having issues! I used the right sleeve, but the plunger feels really tight inside the coil.
If I pull the plunger down *out of the coil* then the targets will drop like they're supposed to and it will push them back up like it should *with the PF up*, but struggles when the playfield is in the cab like it should be.
Any ideas?? The springs are hooked up like they should be btw.
