Laser Disk - Pioneer LD-V1000 won't play
arcaderob
New York
I added a manual "play" button and cleaned the Optics as documented on http://www.dragons-lair-project.com , it looks like the LD-V1000 can't recognize the disk. It used to play after a hundred or so "play" commands, but now won't play at all. If I override the case open switch, and press play I see the head move a little and go up and down twice. Is this the normal behavior? I assume it is trying to find the disk.
So at start:
Head is at position closest to center
Blue Laser light is on
Goes up and down twice.
Platter does not rotate.
Does anyone know what the correct start up procedure is, or what could be wrong with it?
Robert
Oh, and I forgot to add:
When cleaning the optics I moved the head assembly and it skipped a few teeth.... Is that bad? If it is how to I reset it to the proper position?
Robert
