Laser Cue Scoring/flipper prob.
VideoRob
Plainfield, Connecticut
My Laser Cue pin is messing up. Both flippers work but when actuating the right side flipper, the score jumps up without the ball hitting any targets or spinner. Even before shooting the ball the right flipper, when hit, bumps the score up.
Is this a wiring problem or a board problem?
Check the right side flipper coil and see if any wires came loose or missing or broken diodes on the coil and also check the EOS switch make sure they are adjusted properly and clean
