larger monitor into smaller 19 inch frame? Main Event Cab
Justme123
Texas
I was able to score a fully working Main Event cabinet , I would like to turn it into a 4 player multicade but not sure if I can put in a larger monitor? Has anyone put anything larger into one of these?
I am looking at replacing the control panel for a better 4 player one.
Only way to tell if you can (which most cases there aren't but anything is possible) - you'd have to take the monitor out and measure the total size of a 25" monitor (which I'd expect you'd want).
Like measure the entire mounting hardware and everything - width/height. And then if your cab is able to fix a 25" monitor (entirely and easily, of course), then you'd have to figure out a way to mount the entire assembly.
As far as control panel, I think it's looks like a gauntlet style panel, no? I'd see how the bottom of the control panel is mounted, and then I'd build a new control panel box that looks like the Konami 4 player panels (or Captain America Data east, which I have one actually).. and then figure out a way to mount it into/onto your cabinet firmly.
with cabinets, most of the time you're gonna have to get creative
