Lamp Issue, Multiple Lighting When Only One Should, Diode Reading .63 Okay?
jalpert
Colorado
I'm trying to figure out why a BUNCH of lights on my White Water have a problem where they light when they shouldn't. In several instances, 2 lights are lighting when only one should.
Per pinrepair.com I have been testing some of the diodes and I should get a reading between .4 and .6. On some of the diodes I am getting a reading just barely about .6, .63 for example.
Could a .63 diode reading be causing the problem or is the .4 to .6 just a general guide and .63 is okay? Thanks!
.63 is okay. Close to zero or open is not. In your case you'll be looking for shorted diodes.
So, I tested all the transistors on the driver board, I tested all the diodes they are fine, I looked for shorts etc but I didn't see any..... what now?
I fixed it. I did have a short, I needed to look for the shorts at the connector level, not lamp by lamp. Fixed a short and now all the lamps are working properly.
So where was the short at? I'am asking so I know how to identify a short when I need to. Feels good to do it yourself huh? I bet, congratulations on the fix.
Here is what I did. Remember, I am new, so this could have been skill, this could have been luck, I dunno but here it goes:
I opened up the backbox and I disconnected 2 molex connectors, 1 for the lamp rows and 1 for the lamp columns. I know which ones they were because the lamp matrix page in the manual literally told me the location.
I set my digital multi meter to test mode, the mode that plays a tone when there is a completed circuit. (or will beep when the red lead touches the black lead)
Each pin on the connector is 1 column or 1 row of the lap matrix. For example, lamp 34 is row 3 column 4 or pin #3 on the row connector and pin #4 on the column connector. I started at pin 1 of the row connector and touched every pin of the column connector. Then I went on to row 2 etc. In my case, the DMM sounded at lamp number 55. I knew that my problem had to be near lamp 55 (row 5 column 5)
I figured the best places to start looked closely were 54,45,56,65. This was my best guess as a place to start because if 55 was shorted than I figured the problem had to be a connection that was physically close to it.
I started at 54 and that's where I found my issue. I had installed some LEDs a few days prior and when I took a look at the lamp socket the two leads that had wires soldered on to each other were touching. I slid them apart and everything went immediately back to normal.
Hope this helps!
