joeycuda
Laminate application to plywood vs particleboard - stability?
This question is regarding my MC cabaret project, which I quit on after the laminate I applied to the sides of my new cabinet bubbled/lifted in spots. I don't think that I had an issue with applying the contact cement, as I applied a couple of coats to both the laminate and cabinet, just as instructed. Think it might be either
-The new cabinet sides I made are 3/4" birch ply. Could it be that the plywood moves more than pb, so with the wood movement, the laminate loosened up?
-The garage is humid at times, so could humidity have been a factor?
Either way, the laminate is being stripped off. I got this laminate really cheap, so it's mostly time that I've lost here.
I'm kinda considering rebuilding the whole damn cabinet, but particle board like the original cabinet. I wonder if laminate will adhere to pb better in the long run? It or MDF should be absolutely dimensionally stable?
thanks for reading
thanks for reading
