kjeffery New member VAPS Joined Nov 15, 2009 Messages 4,502 Reaction score 49 Location Walcott, Iowa Jun 18, 2011 #1 I wandering if I could prime my cab with auto 2k urethane primer then spray krylon satin black over it. Would this be okay, is krylon an enamel? Would these two react or should i be good to go?
cadillacman Well-known member VAPS Joined Nov 25, 2007 Messages 15,504 Reaction score 542 Location Roscoe, Illinois Jun 18, 2011 #2 for the most part primer is primer.. let it dry well, several days. THe two different solvents is where your peoblem will be.. if the primers still damp it could react with the paint.. once dry dry should be ok. DO a few dust coats to make sure, sand back downto get rid if roughness then spray with the black with a few wet coats...
OP OP kjeffery New member VAPS Joined Nov 15, 2009 Messages 4,502 Reaction score 49 Location Walcott, Iowa Jun 18, 2011 #3 cadillacman said: for the most part primer is primer.. let it dry well, several days. THe two different solvents is where your peoblem will be.. if the primers still damp it could react with the paint.. once dry dry should be ok. DO a few dust coats to make sure, sand back downto get rid if roughness then spray with the black with a few wet coats... Click to expand... The primer dries within 15mins, totaly cures within a day so i should be good the next day to sand the primer with 400 and shoot the black on
bryan95502 Active member Donor 2011, 2013 VAPS Joined May 27, 2008 Messages 1,287 Reaction score 8 Location Spartanburg, South Carolina Jun 18, 2011 #4 2k primers are catalyzed.. Once dry you can topcoat with most anything Cheap spray can primers or lacquer based primers.. well they never really dry!
cadillacman Well-known member VAPS Joined Nov 25, 2007 Messages 15,504 Reaction score 542 Location Roscoe, Illinois Jun 18, 2011 #5 oh snap im an idiot... theyre esentially epoxy promer right? yeha man you cna put whatever you want on top of that..
