SilverDuck
I have a med res KTM-F 26 monitor. I'm trying to put it in my Konami Racing Jam machine. I made some wire harnesses, but the monitor just comes on solid green. Just like a big green light bulb.
The video input marking on the board is tricky.
Right above the input pins, it is marked
HS VS E R G B
HS VS E B G R
I know HS is horiz sync, VS is vert sync, and E is video ground?
What is the propper orientation for RGB?
Do I need to connect both horiz and vert sync?
HS VS E R G B
HS VS E B G R
