KT-2001SF cap list?
modessitt
Austin, Texas
Anybody got one so I don't have to build it from scratch? Supposedly it just had a line on the screen, but I haven't seen it run yet to know whether it was horizontal collapse or vertical collapse. I plan to recap it and check it for cold solder, and check the transistors.
If anyone can help, I'd appreciate it...
Well, the idiot "other tech" who let it sit for three weeks without looking at it will be glad to know that the horizontal deflection loss was a result of a cold solder joint on L402, which was the last part before it hit the yoke connector.
As it turns out, the model is a KT-2001SF, but the chassis is the regular K1-2-V0. For anyone who ever cares, here is the cap kit list:
C151 - 10uf 50v
C207 - 1uf 50v
C208 - 10uf 50v
C209 - 220uf 16v
C210 - 10uf 160v
C212 - 10uf 160v
C213 - 100uf 160v
C303 - 1uf 50v
C401 - 1uf 50v
C402 - 1uf 50v
C407 - 33uf 16v
C409 - 10uf 50v
C502 - 10uf 350v
C503 - 33uf 50v
C504 - 3.3uf 100v
C505 - 470uf 25v
C507 - 470uf 16v
C509 - 470uf 25v
C603 - 0.47uf 50v
C605 - 4.7uf 50v
C610 - 2.2uf 350v
C611 - 100uf 16v
C614 - 100uf 160v
C615 - 100uf 160v
Anybody happen to know which is the width cap on this chassis? The ferrite core of the width coil is frozen solid, and the pic is just a bit too big...
C151 - 10uf 50v
C207 - 1uf 50v
C208 - 10uf 50v
C209 - 220uf 16v
C210 - 10uf 160v
C212 - 10uf 160v
C213 - 100uf 160v
C303 - 1uf 50v
C401 - 1uf 50v
C402 - 1uf 50v
C407 - 33uf 16v
C409 - 10uf 50v
C502 - 10uf 350v
C503 - 33uf 50v
C504 - 3.3uf 100v
C505 - 470uf 25v
C507 - 470uf 16v
C509 - 470uf 25v
C603 - 0.47uf 50v
C605 - 4.7uf 50v
C610 - 2.2uf 350v
C611 - 100uf 16v
C614 - 100uf 160v
C615 - 100uf 160v
Great job on that cap sheet it was exact to mine which I pulled from a 2001 SF Kortek board which was original never touched. And if anyone is interested in knowing the flyback on that model is Elim Tech Corp TCA-50B31
I repaired one of these and tested C601 using my ESR Meter and found it failed replaced that cap with a 330uf 400wv
