kspiff
I'm going to use this post to keep my thoughts collected as I (futilely) attempt to repair the BZ I got from Mod.
Work done so far:
Scraped solder off analog vector generator PCB's edge contacts. May replace the contacts but for now it will conduct.
Repaired edge connector w/ epoxy and replaced bad +5V split pin.
Replaced faulty VR3 (+15V 1A voltage regulator) w/ NTE cross-reference match.
Known:
Red light comes on on the aux board, analog vector generator, and G05 chassis.
Good voltages from ARII.
Good voltages on analog vector generator PCB transistor outputs for VR1, VR2, VR3, Q4, Q5, Q6.
Fluorescents are dead.
Known to-do list:
Replace 2 leg levelers on bottom of cabinet (including mounts).
Replace G05 fuses F600 and F700 (2A 250V fast blow).
Replace components of lights fixtures (new bulbs, starters, ballasts, possibly new sockets).
Replace left handle + button plug, right handle's button bezel (parts in transit).
Replace start button/cone (cone in transit).
Replace coin door parts (some parts in transit).
Sooner or later:
Monitor get well kit.
Switching PSU for common voltages (maybe).
Reproduce step.
Reproduce back door.
General cabinet touch-ups (repaint black areas, touch up edges, maybe new molding).
Parts wanted:
Archer repro CPO.
Brasington high score save kit.
Volume pot + mounting bracket.
Metal bracket that helps secure periscope at top of cabinet (identical to the metal bracket that secures the periscope by the CP).
Warning sticker that goes underneath the step.
Original manual / schematics in Fine-Mint condition.
EDIT: Well I had a stupid question here, but I figured out my mistake. Since I can't delete the post I decided to turn it into a sort of BZ repair log.
Work done so far:
Known:
Known to-do list:
Sooner or later:
Reproduce step.
Parts wanted:
Archer repro CPO.
