Here is another picture w/ notes...
Heres from the PM
Originally Posted by Ohmerone
Does the heat sink get warm?
what's the number on the Ic in the power supply?
plug it in and measure the ac and the dc on the bridge Diode?
seen on pic#5
the big filter cap ground is the hot chassis ground.
it should have about 160v dc on the filter at all times.
the cold is the on the other side of the switch mode power supply
on any of the ground traces and its common to connect to the frame
of monitor or dag/ground wire around the tube, just to make sure
your reading the voltages correctly and using the correct ground.
Its not the 4 pin ic!!
Th102 is ok
Yes that's the heatsink..
I'm talking about the Ic on that heatsink.
It needs to have about 160v dc on one of the pins of that
Ic...its the PWM Ic for the primary.
If its cold odds are its not working.
yes that's the bridge rectifier..
