Hi , I have a Silver Strike 2007 cabinet with this monitor that I want to put a golden tee complete in. The problem I first saw is the vga is directly hooked to the back of the monitor from the nighthawk computer. I need a standard low res cga from the golden tee jamma harness to plug into the monitor. I don't know if their is a connection for this to the monitor and if its as simple as disconnecting the vga cable from the monitor and plugging in the straight white cga somewhere on the monitor. I'm sorry I'm not real familiar with this so thats why I'm asking here so maybe someone familiar with this monitor could help me. I also see the monitor is in the 50 khz range were the golden tee is somewhere around the 15 khz range so I don't know if this can be done unless this Kortek can be used for other resolutions. Thanks
