Kortek KTX26 Vertical Collapse
GrimJack0
Pennsylvania
I have a Kortek KTX26 with vertical collapse down to a single line. What went bad? Thanks to everyone that have helped me on this forum.
Well, do a cap kit, find the vertical IC and look for cold solder, check the vertical size pot to make sure it's not broken, make sure the vertical yoke isn't bad (and is hooked up properly), look for broken traces around the vertical IC or yoke connector, and if all else fails, try replacing the vertical IC.
And no, I don't know where the vertical IC is...
