This monitor died with a burned D605 which is a UF206. I'm not sure what this UF206 is or where to buy it. It looks like a diode. I found this link (attached) that shows you replace D605 with a jumper, take out a cap, and add a different cap. I did this and the monitor ran for about 10 mins. Then I heard a pop and now it squeals loudly. I replaced the HOT, D5072 (NTE 2331) as the HOT was shorted. When I fired it up, it immediately blew the HOT again. I'm stumped. I also pulled L401 and tested the power supply. I hooked it to a 100W light bulb and the light worked fine. Any suggestions.
Thanks,
Clay
http://forums.arcade-museum.com/attachment.php?attachmentid=48331&d=1285800386
Thanks,
Clay
