Kortek KT-2914F issue
Nethawk86
Donor 2016, 2020
Litchfield Park, Arizona
Ok, just recapped this chassis and it's been working fine. Sold the game and it worked fine prior to him picking it up. He loads it up on its back in his van and gets home. He fires it up and then nothing but sound. I tell him to make sure everything is connected and notice the chassis was loose and the holes weren't aligned , so as he moves the chassis he gets a dot on the screen, then finally gets a permanent vertical squish. He said the neck board had a blinking light and come to find it was a diode that was arching internally. So now it's still a vertical squish. I checked all solder joints for continuity and everything checked out, no cold or cracked joints. Again it was working, then he moved it and the chassis was loose in the cab, now it's vertical squish. Any help?
Shoulda coulda woulda lol. Screws were missing and it wasn't noticed. No visible damage, no arc points noticed. The yoke was loose and badly heat damaged but I hot glued it back stationary. That wouldn't effect vertical squish though. Usually a cap or cold solder joint. But this was working fine, then shipped and now nothing. And that diode arcing has me focusing on the neck board.
