mike11
Chassis was recapped .....: and I changed the H hold pot which was bad now I get a pic but its ugly nasty and can't be centered ..... H position pot makes it as good as you see in the pic ... With the ground wire on the chassis the wiggle of everything is 10x worse..... Alot of caps were just done before I got the machine....... All I changed were the lil 1uf and 10uf ones ..... What are your thoughts guys ...... I flip from + to - sync and all it does is makes its stable but overlapping and tilted .....the pic rotated when I uploaded .... It does display is the correct position kinda
