Konami Winding Heat system Kr107
rucinskj
BANNED: MANY DEALS ENDED VERY POORLY - ITEMS REPOR
Scotia, New York
I have a winding heat which uses Konamis sytem KR107 i beleive. I plug it in and the board flashes the number 5. I have no display and i know the monitor works because its fine in my cruisin. Anyboady have any experience with this? Thanks!
John
Hi, if there´s no video, the problem should be in pwb A, check EPROM sockets or CPU POWER PC pins for bad contacts (take care the last is SMD)
I m sorry, PWB A is the code of the upper Printed circuit board, and SMD is Surface mounted device, means the mounting type that is difficult to solder, that´s what I warned you about, regards
Thank you. I will check it out. Its weird. I fired it up initially, no code, then the screen would just start going throught the test and reboot. It did this 3 times now it has the number 5 error and no display.
