FS Parts: Konami Simpsons Bowling PCB marquee complete control panel
easy_rider
Donor 2011, 2016
Ohio
I have a complete simpsons bowling kit
came off a konami cabinet and should bolt up to most konami or midway cabs
comes with PCB stack with the attached cd drive (untested would assume disc inside player)
complete and looks great. no way to test, assume not working
complete CORRECT control panel box and top as shown. this is not as wide as a tmnt 4 player cp but the same size to fit those konami cabs and has latches and wood box. includes trackball and buttons and wiring as shown. this overlay is very rare and should clean up nicely.
also mint condition marquee as shown. very cherry. and Manual
you get the whole kit shipped for SOLD
now keep in mind this control panel is pretty enormous so shipping wont be cheap.
ill try to get pics of the pcb later. its all there
Pcb stack in the cage?
Numbers matching? Pcb cage / marq/ pcb?
there isnt an external cage its a giant stack that is attached together with screws and the player under the green boards.
number matching marquee?
The pcb stack and scsi drive came mounted inside a cage. This cage had a sticker with the serial number found on the pcb. Which would match the marquee holofoil serial. Ie. Original Number matching kit pieces.
Yes the cd drive is mounted in the cage with the boards like all connected in one stack
